Hi,
I like this forum and especially the show-off and mailday threads. But it is possible to add a like button below each post? That would make it easier to respond.
Thank you.
Best regards,
Aron
Like Button
- Has liked: 122 times
- Been liked: 49 times
Re: Like Button
There is a "Thanks for Posts" extension that Mindcycle can likely install. There's also an option to change the language of it to "Like" instead of "Thanks". Solid suggestion, though it probably should have been posted in the "OFF-TOPIC" section instead of "THE HOBBY".
https://www.phpbb.com/customise/db/exte ... r_posts_2/
- Has liked: 750 times
- Been liked: 186 times
Re: Like Button
Hey Aron, great suggestion. I will definitely look into ading like button. Sound like there is one out there per Frank so that could be a nice addition to the forum.Duncancollector wrote: Sat Aug 26, 2023 12:19 pm Hi,
Thank you.
Best regards,
Aron
I did want to mention that if you are just wanting to comment on a single post you can use the "Reply with Quote" button (I think it's just called Quote on mobile) and that will copy the post into your reply. I didn't know if that was ultimately what you were looking to do or if you just wanted to see a like button like we have on IG, Facebook, etc.. Just lmk.
Re: Like Button
Hi, thanks for your reply.mindcycle wrote: Wed Aug 30, 2023 8:44 am
Yes, I am looking for a like button like it is on Instagram or Facebook. This kind of a response to comment is the fastest way. A quote needs too much space in a thread if I only want to say I like your card.
Thanks so much for your time.
Re: Like Button
Sorry it took awhile but I finally got this setup. Thanks again for the suggestion!
viewtopic.php?p=3672#p3672
Re: Like Button
Thank you so much @mindcycle. Thanks so much for your work and your passion to do it. A+++++
